washer problems
my maytag washer will not spin or agitate but sounds as if it is ,meaning no weird noises
What is the complete model number of the washer?
— Begin quote from malon66;746538
Gene , thank you for replying. the Model number is pavt234aww Serial 22045877ex
Gene , the MN is PAVT234AWW
Tilt the washer back and remove the belt. Check the belt. Check how freely the drain pump pulley and the transmission pulley are moving in both directions. Post the results.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5171962
