Washer "throwing" the belt from the pullry.
I have a Frigidaire LTF530FS0 Front load washing machine. The belt keeps coming off, upon further inspection I noticed that the Pulley - Drum - Reinfor is rocking back and forth and throws the belt off. i have tried to remove the pulley to see if there are bearings behind but I cant get it off…do I need a pulley puller to remove it? Are there bearings behind there? I have tried to tighten the bolt that holds the pulley on but I cant get it tight enough, the pulley hass sunken too far past the shaft for the bolt to hold it in place. Thank you in advance for any help you can give
Something is damaged in the pulley section, and you will need to take it off if you can.
Here is the link to the service manual which should be of great help.
http://www.emaservicetips.com/pdfs/360_TumbleActionWashers.pdf
Hello, this is the first time posting, so please bear with me i have a front load frigidaire gallery washing machine it’s about 11 years old, i just bought the house and things seemed to be working for a couple of loads and then the washer stop turning… wouldn’t spin but the motor was working as i heard the motor work through the cyles…so i open the back of the machine and there i saw the belt had come off, so i thought no problem will just put back on right…but as i put the belt back on did this at least half a dozen times every time i would spin the pully to rotate the pulley wheel the belt would just come right off… the belt is in excellent conditions no tears the motor rods is also ok i think turn smoothy as does the drum pulley and spider wheel… so what can i do to make the belt stay on, i have read that i might have to remove the drum pulley and put a washer, between the outer bearing and spider wheel pulley, could it be an alignment issue where the motor shaft and the spider pulley aren’t perfect lining up…also i should also mention that there is an alignment problem, i would think because of the clue that the belt has eaten away at the outer plastic shell, it must be rubbing against it, so perhaps the shaft is too far into the tub…i know i’ve been going on here, and advice and tips would be much appreicated, just had a second baby and the wife wants to use the washer badly…please help…thanks,
While using it on normal cycle, added heat and heater dry options, it produces too much heat. That resulted into melting down of lower spray arm, silver basket and lower rack wheels. Is there a way to reduce the heat?
