My Amana made a whistling noise when agitating then I noticed when in regular/fast it started to hesitate then go I tried Regular/slow and it did the same thing, tried Gentle/fast and was ok for few minutes then it started to do the same thing. Meanwhile it started to leak small amount of water from under the washer small but steady. It fills with water, spins and empties just fine.
This washer is actually 10 years old.
Can you tell me what the problem is. Would it be worth fixing or buying new.
Thanks in advance for any help you can give me.
ggid
