The spin basket in this washer would not spin, pump removes most of the water from clothes.
Lid switch tested okay,LED on motor flashes according to the test sheet supplied,when pump is removing water the motor remains idle.
Motor was changed by another technician,yet problem was not solved.
This video should help you
http://www.youtube.com/watch?v=fp2iDOaGRgg
