washer repair
after the washer fills it hums then nothing.few minutes later it hums:confused:
[SIZE=3]Post model number for more accurate information. But what you are describing sounds like the motor can’t turn and cutting off because it is overheating. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]There are a few things that will cause this. One is that something is hung in the water pump. This is rare on Whirlpool but I do occasionally see it. [/SIZE]
[SIZE=3] [/SIZE]
[SIZE=3]Check that first and post what you find along with you model number. [/SIZE]
http://www.appliance-repair-it.com/clothes-washer-repair.html
