When it gets to the final spin cycle, half the time it just clicks through it. Some times it works fine. I replaced the timer but it still works only half the time. When I manually turn the timer button to spin, it works fine. Any thoughts?
Did you figure out the problem because I have the same problem. I replaced timer but that wasn’t the problem.
Matt
No. I took out the timer and, for now, just re-spin manually when necessary.
