Our two year old Maytag washer loudly squeaks in the regular wash cycle only. I am handy but wonder is this a repairman only fix. Thank you, Auxesis
Sounds to me like the brake is slipping… probably sqeeks when it stops spinning too… Sometimes you can adjust the release cam other times need new brake
Break cam:
http://www.servicematters.com/maytag_library/docs/TDL-0037A-B.pdf
Other Info:
http://www.servicematters.com/maytag_library/html/index.html
washer spin and agitate at the same time
