The washer stopped in the middle of the drain cycle with a clicking sound. Went and unplugged the washer powered down and back up, changed the dial to drain and spin. Washer started to drain for a couple of seconds then started the clicking again. Any ideas as to the problem?
Well, if we were there with you we would put the machine into test mode and see if we could learn anything. Since we are not there we recommend that you do this.
Here is a service manual for your machine which will tell you how, and how to interpret the results if it will enter test mode.
