Washer stops after filling with water
Washer stops in the after filling with water. Won’t agitate or spin. However, if I turn the rotatry control knob to just the right place I can get the spin cycle strated and empty the water. Should I be looking to rplace the timer, lid switch, check switch or something else?
The first thing I would check is the lid switches.
You can find the complete troubleshooting instructions in one of my previous posts: http://forum.appliancepartspros.com/washer-repair/558-maytag-washer.html
Here are the break down diagrams for the Maytag washer http://www.appliancepartspros.com/partsearch/model.aspx?diagram_id=818854&&model_id=26655
The dual top plate heating small or inside heating element will only heat on a very low number like 1 o2 and again on high. When the switch is place on the middle numbers the burner doesn’t heat at all. I assume the problem may be the infinite switch. Could you give advise.
Thanks George
Dishwasher fills (drains too), washing + sensing lights come on. Hum, but cycle never starts.
After "Sani Rinse" and "Air Dry" off/on, all lights come on, then normal wash light comes on, fills with water, hums a bit, then drains.
