My washer stops after completing the wash cycle right before spin cycle. I was able to lift the lid and drop it several times and the cycle would start up again. It won’t do that now. What is wrong?
Most likely your lid switch is broken, a common occurrence on these models.
You can test this theory by taking off the cabinet and by passing the lid switch, or test the lid switch for continuity.
