My washer stops after washing and wont fill with water when it gets to any rinse cycle. I have to manually turn it back to the start of the cycle for it to fill and then return it to the rinse cycle for it to continue. What could be the problem??
When you set the temperature for cold/cold, do you get cold water during the wash cycle? If so, looks like a bad timer. If you don’t get cold water in wash cycle, could be clogged screen in water inlet valve or the valve is faulty.
http://www.appliancepartspros.com/whirlpool-timer-8546685-ap3691045.html
Eric
Thanks Eric, and no the cold water does not work for the wash cycle… Thanks for this insight!
Thanks Eric, and no the cold water does not work for the wash cycle… Thanks for this insight![LEFT][COLOR=#000000]
[/COLOR][/LEFT]
Your welcome. Here’s the inlet valve if you need it.
http://www.appliancepartspros.com/whirlpool-valve-8578341-ap3890458.html
Eric
