Washer Stops spinning and power turns off
I have a Whirlpool duet sport. The washer will spin through the whole cycle without clothes in it. When you put clothes in. It will start the spin and stop when it goes to high spin and power will go off. It seems like the bowl shakes around way to much. I have replaced the belt, 2 shocks (used ones) made sure it was level. I had a repair guy come in and he said it was probably uneven, or the water pump. I confirmed the water is still pumping out. The springs, shaft and bearings are all good. I am at my wits end trying to figure this out PLEASE help.
