10/29/08
Hi,
I am trying to replace the timer on my Frigidaire washer, can anyone give me instructions on doing this? Any and all help will be greatly appreciated. Thanks in advance.
Barry
10/29/08
Hi,
Barry
remove the top push the knob in so its off then unscrew it turning to the left then remove dial remove the 2 screws holding timer in then bring it up through the top you’ll have to remove wires write it down where they go there is a mess of them. Some of those are color coded so you cant screw up to bad
