Washer will not drain after spin cycle, tried the trouble shoot in Manual
Bosch front loading washer won’t drain and door locks. presents with error E:04. Tried the trouble shooting guide without results. Was able to disconnect the power and open the door to get wet laundry out. Machine will not pump out water. Drain line is clear without debris.
Is there something I can to to correct this problem:confused:
