Hello all-
So I have a front loading washer machine that will not spin all, when powered on, it will fill up with water, drain, but will not spin, just hum. I called the repair guy, real nice, asked if I was handy, advised for me tilt the machine on its back and look up. If you see the belt hanging there, its the belt usually.
Well doing this, I did not see any belts hanging, but I did find a tech data sheet for the machine, typed on the inside.
I discovered the machine has its on diagnostic mode in it that will tell you what could be going on with the machine. I did this and the read out says E59 No tacho signal for 3 seconds.
In the manual for these errors, it says check the belt, if in good condition remove the belt.
–The belt is in mint condition
Now the belt is removed see if the electric pulley spins freely, in both directions. If it does, check to see if the resistance in the motor is normal.
---- The pulley spins freely in both directions.
If the motor pulley spins freely in both directions, test the resistance measured in Ohms across the PINs on the motor.
–The resistance on the moter between PIN 4 and PIN 5 is at 117.6 Ohms, and the resistance between PIN 1 and PIN 2, PIN 1 and 3, and PIN 2 and 3, are about 4-5. According the manual the motor is good.
With the belt removed check to see if the drum will spin in both directions.
– The drum does not spin in any direction, it will kind of turn in both directions, but feels like it stuck or jammed. Visual inspection on baffles on the back side of the drum, show a oil drip trail from the center of the back of the drum. The same point where the main pulley in the brain train connects to the back of the drum. Good dark oil is dripping straight down from here.
With the machine powered on, and the back w/ the belt both off. The machine WILL fill the up, and WILL suck the water out of the drum. The motor WILL spin in both directions, like normal.
I am left to believe that the problem lays with the drum bearings. This is because the motor is working, but the drum still seems ‘stuck’.
If this is true, will these parts fix it?
I think it might a little expensive from this site:
Rear outer tub assembly (shell) Part #: AP2578105 Price : $197.55
[FRIGIDAIRE GLTF2940FS0 (07 - MOTOR/TUB) | Bell Parts Appliance Model Lookup](http://www.appliancepartspros.com/part_details.aspx?part_id=2578105"]Part Details - FRIGIDAIRE Rear outer tub assembly (shell), part number: AP2578105[/URL].
I found another at Bellparts:
Drum Assy,spin Basket Part #: 134360910 Price : $175.49
[URL="http://lookup.bellparts.com/lookup/frigidaire/44493/00000281)
Thanks in advance for all your words on this issue!
