washer will not spin
washer won’t spin. checked drain hose and filter pump and tub and no obstructions found. tried different spin settings and still will not spin. timer shows 7 minutes and drum does the final tumbles and stops.
Look inside the lower service panel and you will find tech notes that show you how to put it into a diagnostic mode. Focus on the speed control board and the door lock assembly for testing.
