I am trying to figure out why my washer will not Agitate. Belts good. Spin works. Isn’t there a coupler under Agitator? Please help.
What is the complete model number of the washer?
Model # WJSR2080T6WW
Yes, there is a coupling (310 on the diagram) which can cause such problem. Remove the agitator and check the coupling.
Here are the breakdown diagrams and http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230166
I am having issues getting the Agitator off. Is there a special way to remove it?
— Begin quote from timdm;192918
You can find some useful information in one of our previous threads: http://forum.appliancepartspros.com/washer-repair/26722-how-do-i-remove-agitator-ge-washing-machine.html
Thanks Gene. You have helped me alot!
I have the same problem with the same washer but the splines in the coupling don’t appear to be too bad.
Replace anyway? Other suggestions?
Mine was not bad either. But I changed it and it works. Only heads up I have is when putting the new coupling on, be careful to not hit it to hard.
Got the part today and it works perfectly! Thanks for the help
