After using this site to find a problem I had with my washer not draining I removed the mangled popsicle stick from the drain pump inlet and put everything back together to discover the washer would now drain but not agitate or spin. I hear the switches cycling but no agitation. I might add that I heard a popping sound when I was moving the washer back into place but I didn’t smell anything. Any advice would be greatly appreciated…
Are there fuses…?
Check to see that the belt is not broken.
If it is ok, a possible problem is the speed control board.
Here is the service manual which will show you how to do some troubleshooting. See page 50 in particular.
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
— Begin quote from sidfink43;130037
Thanks! I’ll take your advice and let you know what I find!
