Washer won't drain during spin cycle. Water Pump Belt discovered on floor
Our washer seems to be operating normally, goes through all cycles including spin, but it doesn’t drain. When we looked under the washer, we found the water pump belt on the floor.
Our first plan is to put the belt back on. How do we tighten it?
Thank you!
