Washer Won't Drain Spin Or Agitate
Washer will fill but will not agitate spin rinse or drain. I have replaced the timer.
Does the timer advance? If not check your lid switch.
Lid switch does not have a fuse. Switch allows 120v to go back to motor and operate. The lid switch is a saftey device to prevent people from putting their hands into the machine when it is running. To verify switch is bad, unplug from wall, unplug lid switch and place ohm meter leads across lid switch. Activate lid switch and verify reading goes to zero, if not replace switch.
I replace the lid switch. I still don’t have anything. What else might it be?
Does the motor run? Did you check the belts?
The motor isn’t running. The belts look okay.
I replace all switches and now something keeps blowing the fuse located at the front oof the machine
These two switches on the lid switch assembly should be properly adjusted so when one of them is "open" the other one is "closed".
It wonot drain water after it rinse?
I got the switdhes adjusted. The washer now spins but won’t fill up. Before it would fill but nothing else.
