Washer won't drain.
My washer went threw all it’s cycles till it got to the spin cycle. It is still 1/3 full of water and won’t do anything else when put onto other cycles besides fill with water. You can hear the control panel clicking when on but that’s it. Any ideas on what it could be would be great
I would check the lid switch assembly. It has two switches and a fuse on it. See diagram Top replacement parts for MAYTAG LAT3910AAW WASHER-TOP LOADING | AppliancePartsPros.com
Parts 5, 10, 16, 22
Part 5 is the lid check switch. I’ve seen a lot of those go bad over the years.
