I have aFrigidaire front loading washer that will not go through the spin cycle. EVrything else works fine. I have read that perhaps it is the door lock assembly. Any thoughts?
— Begin quote from sidfink43;496830
Inside the lower service panel are some tech notes that will tell you how to test things.
Focus on the speed/motor contorl unit and the door lock assembly. That is where these units usually fail.
Thank you!!
