washer won't heat up
Hello, I have a Maytag Neptune gas dryer. The machine works, but won’t heat up. I opened the front and tried to run it. I don’t see a spark and also there is no gas going through. I am assuming is the the igniter and the some sort of gas control valve. Could you help me with this. Point me in the right direction as to what parts could possibly be bad. Thank you for the help.
Also if you guys know where i could get the diagrams i would appreciate that as well.
sincerely,
ed.
Hi Ed,
I would check to see if I was getting power to the ignitor. If I was and the ignitor was not working I would replace it.
Here is the service manual for your model dryer. It has a lot of great information in it for troubleshooting.
http://appliancejunk.com/forums/index.php?action=downloads;sa=view;down=386
