Washer won't spin - coupler ok
Ok guys ran into this little gem this morning.
The washer filled with water fine. It stopped there. It won’t spin at all, on any setting of the dial.
I can hear a noise which I believed to be the motor, but when that noise is happening, nothing is spinning. After searching the forum, it looked like the problem might be the plastic coupler.
So, I took the machine apart quickly via the YT video I found here (thanks for that btw!) but the coupler is intact on both sides of the rubber collar.
I haven’t plugged the machine back in yet to see what I can see if anything, but does anybody have any suggestions on where I should look next?
Thanks!
I should specify…it doesn’t spin, agitage, nothing. The drum doesn’t move at all that I’ve seen since this began this morning.
If I spin the drum by hand, the coupler does not move. Should it? I guess at this point I’m looking at either the clutch or the trans?
Also, could the timer affect this at all?
I did get a resolution. I replaced the lid switch, which was a piece of cake.
I still don’t understand how the lid switch could cause what I described above, but everyone I talked to was convinced that was it, and sure enough, that was the problem! I found it at an appliance repair shop for $53.
Well, I guess i will be off to find a lid switch then. it’s pretty easy to fix? that makes no sense to me either. is there anyway to test the lid switch b4 i go buy it for nothing? i will do some research on that. thanks so much for replying so swiftly. I will update.
thanks again.
I have another question for you. I put my machine back together and started a cycle.After the fill was done I pushed down on the lid switch and nothing happened. does that mean it’s not my lid switch that is the problem?
