Washer won't spin
Well my washer won’t spin without a little help I’ve changed the clutch ,the drain pump cuz it was leaking new dog bones I’ve tried bypassing the lid switch the rubber peice between the motor and the trans r new I took the trans cover off make sure no gears we’re messed up and nothing idk plz help ready to roll to the curb
Does it agitate at all? Have you tried replacing the shift actuator?
Yup agitates no I haven’t tried replacing acu u is there a way I can test it to c if it’s bad or good
