Hello All,
My washer will agitate and drain but the tub wont spin during the spin cylce. I just replaced the clutch assembly but that didnt fix the issue. Could the issue be the washer drive block?
Hello All,
Check and make sure the brakes are releasing, and also that the clutch is turning during the spin cycle.
If so, then yes, the drive block could be the problem.
Are there any videos out there that i can look at to check the clutch and brakes? I have no clue how to do either.
I think I figured out how to check the clutch by simply tilting the machine backwards. I don’t see the clutch spinning at all. That’s if the entire cylinder is supposed to spin.
Okay, if it still agitates then that suggests a transmission issue. You should see the clutch housing moving. But first check to see that the new clutch is installed correctly.
