My Whirlpool Washer Fills Up And Agitates Fine But When It Comes Time To Drain Nothing Happens. How Do I Tell If It Is The Pump Or The Switch? It Otherwise Operates Normaly
Hi Ashland
It is almost certainly the lid switch, so take the two screws out of the console, flip it back and you will see a plastic connector coming from the console.
Take it apart and insert a jumper wire in the two outer holes of the connector coming from the console and put the machine in spin mode. If it spins, replace the lid swtich.
Good luck.
Hello everybody
I need to replace the GE oven door gasket
I bought the part already
does anybody know how to replace it? i would really like to try doing it myself
can you send me instructions, pleaaaaaase???
Thanks!!!
belen:)
