My GE washer will fill, it will not agitate, or spin, it just makes a humming sound. It does go through the cycles. I realized the problem after running a load of clothes and when I went to empty the washer, the clothes were wet, but I could tell that the clothes had not actually washed or the water spun out of them. I thought that maybe there was something in the hoses that had kept it from draining completely, so I did remove the hoses from the pump and found nothing. (I thought this was a problem because when I removed the front of the machine casing there was water present). I put it back together and set it too small load with no clothes in it and let it fill again, it filled and then nothing but the humming, I turned the dial to drain and spin, it drained and then again nothing but humming.
Any suggestion?
