Experiencing a problem with washer. The washing machine will not spin clothes or drain water. Can you tell me what could be wrong?
— Begin quote from mbrown;175
Hello . The most likely problem will be the [part]AP4008752[/part]lid switch this also works as a safety, that is why the washer will not spin, as well [part][AP2907492](http://www.appliancepartspros.com/Appliance-Parts/whirlpool-whirlpool-direct-drive-washer-pump-item-number-ap2907492.aspx)[/part] drain pump could be stopped up with a small piece of clothing,then the last thing that comes to mind would be the motor coupling [part]AP3963893[/part]
