Please help. replaced front loader with new front panel,but can’t put spring back to latch door. white plastic handle can’t put back together.door off hindge in two pieces, so close,thanks, fred
Here is your parts breakdown
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mah2400aww
Here is a manual that may help, see Page 20
http://appliancedigest.com/index.php?/files/file/469-16023430-maytag-mah2400aw-compact-washer-service-manual/
You will probably have to join the site to download the manual but it is a good site for the appliance DIYer and has many manuals.
— Begin quote from denman;329683
[16023430 Maytag MAH2400AW Compact Washer Service Manual - ApplianceDigest.com](http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=mah2400aww"]Replacement parts for MAYTAG MAH2400AWW WASHER- HORIZONTAL AXIS | AppliancePartsPros.com[/URL]
[URL="http://appliancedigest.com/index.php?/files/file/469-16023430-maytag-mah2400aw-compact-washer-service-manual/)
appreciate your help,couldn’t seem to download manual. just need advice on how to put the latch back in with the spring. seems so easy, but not sure is i’m doing it correct. how does the spring attach to the latch?
From the manual it looks like spring fits over the latch, then the pin goes through the holes in the spring and the latch. Then he spring ends compress between the door frame giving you the tension.
I tried to down load the picture for you from the manual but the pdf file will not let me copy a graphic.
