washing machine will not cycle
My matag top load washer will fill with water but will not go through any additional cycles after that. You can see the timer manually advancing and making a ticking noise but it will not agitate or rinse. Sometimes if you put the timer in another cycle from perma press to delicate it may continue but usually just nonresponsive
Since it does operate when you can get the timer to engage it, I would try replacing the timer.
If you buy from this site and the part does not fix the problem you can return it, see the Returns Policy for details and conditions.
thanks I ordered it last night
Great, let us know how things turn out.
