sometimes the machine wont start right when it acts up it sounds like the water pump is only working and it wont fill with water i am thinking the control board is bad does anyone have any suggestions?
The problem with GE’s is that the company does not release technical data and support documents, so we are often working in the dark.
Take off the lower service panel and see if you can find some tech notes which may allow you to put the machine in diagnostic mode and trouble shoot it.
Here is a service manual for models close to yours that may also help.
