Washing Machine
I set the water level load to light position to 6 and turned to the spinning position on. I originally thought it was from the black rubber pumps connecting to the plastic drum with the claps tightly but there is no water dripping there. While the spinning was on, I noticed there is water leaking on top of the plastic drum around the rubber belt that eventually overflow to the ground. Also, the belt was slight wet. Do you think the white plastic drum is need to be replaced or can be filled with epoxy on it. Please let me know soon. Thank you!
I am sorry but I really do not understand exactly what your problem is. It sounds like a leak, in which case the way to diagnose the source is to operate the machine with the front panel off. This way you should be able to see where the water is coming from and take appropriate action.
