[SIZE=3]I have amana alw480daw , belt burned up this morning and I would like to know why the belt burned up?[/SIZE]
[SIZE=3] Do you think the motor is gong out or the pump is bad ? How do I determin what the problem is, could you send me a diagram on how to replace belt?[/SIZE]
I had the same problem. Do be aware that the belt needs to be a cloth covered belt to allow for slippage. If your trany is failed, it will be covered under waranty. If the main berring is failed, it is not. Thatโs per Amana.
