washing maching will not drain or spin
My washing machine will fill with water fine and agitate fine, but when it comes to the spin cycle, nothing happens…No humming from the motor or anything…I turn the dial manually, and it will begin to fill but when I put the dial in a position that would call for spinning or draining absolutely nothing…TIMER problem?
This is more than likely a lid switch problem. It can be the timer but its almost always the lid switch.
http://www.appliance-repair-it.com/clothes-washer-repair.html
[SIZE=3]It is not suppose to spin without the lid switch unless someone has bypassed it. If that is the case I recommend replacing it but if the lid switch is bypassed and it still won’t work the timer is a likely cause. [/SIZE]
