Water and Ice
I have a Ge TPX24PPDAWW Fridge. It is just over ten years old. The water in the door was not working, but it would make ice. It started leaking water from one of the valves in the back so I replace the WR57X10023 valve. It no longer leaks water, but now it will not make ice or despense water from the door. Will replacing the other valve fix the water and ice issue. If so, what part should I order and do I need a new wire harness as well.
