Water at the bottom of the frezeer
Each time the refrigerator goes in defrost cycle water is leaking on the freezer side of the system. I check the pan under the freezer and it is in the correct position and there were no noted leaks. The leak appears to be in mid way to the end of the freezer, next to the wall of the freezer. The temperature of the freezer goes up to plus 5 -10 and the refrigerator goes up to about 45.
Not sure why so much water is created during the defrost cycle.
