water collecting in the bottom of fridge
I have removed the rear panel in the freezer and poured hot
water down the drain. It still leaks do something have to be
snaked down the opening to clear.
Nat
Can you tell me where drain tube is located.
rermove the control in the frig section thats where the drain actually is on this one and see if the stem going into back is obstructed if not these friges had a service bulletin and the funnel coming down from freezer into the control/duct in refrigerator was to short and the defrost water would go down the vent instead of the funnel I’ll see if I can get the part number to the funnel I have one laying around here somewhere
The part number to the funnel which goes in the freezer evap area and it is longer is 240365901 thats a frigidaire part number
