Water dispenser doesn’t work. Ice maker works fine. When I press the dispenser the water line under the refrigerator leaks or if I keep pressing the dispenser it breaks free from the connector and water just flows out of the line.
Find where the water line connects together, cut 1/2" off the line and reinstall it into the coupler, if it still leaks, replace the coupler!!!
The pressure builds up and blows the supply line out of the coupler. No water comes out of the dispenser.
The fill tube INSIDE the door is frozen, Call GE consumer affairs # on the owners manual, This has been a problem on a FEW units, MAYBE they will help you out!!!
