My water dispenser is dripping after I fill a glass of water. The drip is fairly constant and may slowly stop after awhile.
My first problem before this was a water leak in part number AP2071735 which is the first water valve from the water linlet to from the house to the refrigerator. This part has 6 screws for a metal plate that secures the water line to the other water valves for the ice and water maker.
I replaced this water valve because of the leak on that metal plate. Since then, the water dispenser drips after filling a glass of water and I did not have this problem previously. Is is possible I have a bad valve (the one I just replaced) or is it another issue?
Should I try a warranty issue on AP2071735, the valve I just replaced?
Is it possible that valve part number AP207136 is also bad?
The two valves also come together in part number AP2071738 (includes the two valves AP2071735 and AP207136).
Any recommendations would be appreciated. Thanks!
Bob Eash
