water dispenser hose leak
Leak occurs only when trying to get water from dispenser. Leak is at bottom of freezer door (looks like dripping along black hose). I know I probably need to replace the hose, but it seems to be stuck and I’m not too sure about pulling it too hard. Is there any trick to replacing this hose. I can get the front panel off and unscrew that top part to loosen the hose. Is there any conduit that the hose snakes through? any help would be appreciated.:confused:
