water dispenser leaks
i have a whirlpool fridge with the ice/water dispenser in the freezer door. the water dispenser is leaking after use. the dispenser switch is off but the water still leaks from dispenser nozzel. i’ve turned the water feed to the fridge off to stop the flow.any advise as to where to start on this repair?:confused:
i live in an area with severe hard water problems…
