water dispenser quit
the water dispenser quit working, however the ice maker works fine. I disconnected the hose from the quick disconnect fitting at the bottom of the front door and had good water flow when the lever was pressed. I can hear the solenoid when the lever is pressed. If the door cover has to be removed, how is this accomplished? Thanks
