Water Dispensing issue
My Hotpoint Fridge water dispenser has quit working
  1. In another fourm I found that most issues were repaired by
    changing the water valve. I did that.
    Part # WR57X10032 and all parts #'s matched.
    The Ice dispenser has been working fine all the time and is now working with the new part, but still no water flow.
    The Light comes on when the switch is activated for water or ice.
What else should I look for.:confused: :confused:
PS I can hear the switch activate when I push the door switch.
After changing the part I held the switch in for three minutes for possible air blocks to release.
I am not sure what else too look for.
[PS changing the water valve switch was very easy.]
HELP!!!
I have received NO answers to my question above about water flow from the dispenser
  1. Replaced the main inlet water valve in back of refrigerator
  2. Ice Maker is ok, so filter is working
  3. NO water dispenses from tube
  4. Temperature was adjusted to 5-5 standard operation temp, I even moved both sides to higher points for a few days and watched the inside temp rise to 36 on Fridge side and just barely at 29 for freezer. So I do not believe water line is freezing.
John Lake
