I have an older amana th21tl. and I have water dripping from the rear upper right corner of the refrigerator compartment. I have tried to look at the schematics and the owners manual for a clue but , no such luck. I am officially clueless. any ideas?
Hi.
What you have is most likely clogged and frozen condensation drain. You need to open the rear panel in the freezer to access the drain. Blow dryer, hot water and some air blown into the drain should help.
Thank you. Post the results.
Simon.
Simon.
I will!! Thanks for the quick reply. I was hoping it was an easy fix since we just decided to use the last of our refund on new porch windows. We are planning on replacing it but that wasn’t in this years plan at all. It has been working without a glitch for many years now. This has been our first issue with it other than replacing things the kids have broken!
You are welcome.
Simon.
