Water filter housing is overflowing (Frigidaire Refrigerator model #FRS26ZRGW6)
Whenever I press the water dispenser, water overflows the water filter housing. Keep in mind that this issue is occurring AFTER I replaced the water filter housing, o-ring, filter. and both water tube elbows. There is plenty of water pressure going into the water filter housing.
Could there be a clog somewhere between the water filter housing and the water dispenser causing this overflow? I’m out of answers at this point.
Thank you in advance for any potential solution that may help to solve this problem.
