The vent that is connected to the top of the kitchen sink. Is it normal for water to come out of it? I know its a vent, but does it function as an overflow too into the kitchen sink? Or is there a blockage causing it to come out the top vent?
Is it Normal for water to discharge from the top vent?
Water comes out and empties into the sink. Is this normal? I thought it was just a vent?
Normally no water should come out the vent. There may be a clog in the drain somewhere.
Just got an estimate to replace my ice maker control board for $280. Is this a good price? Is this something that is easily replaced by an amateur? Please help.
The model number you posted does not come up. Verify and repost it please.
It says kenmore but the repair guy said it’s actually a whirlpool. The model number is 106.52693100. Thx.
If you are talking about the two optic PC boards (emitter & receiver) on both sides in the freezer, this is not too difficult to replace them yourself if you know how to handle a simple tools. The PC board kit will cost you just $86.23, so you can save almost $200.
- The PC board kit AP3137510
Thanks! Miraculously it started to work again after not working for 3 days. Maybe it can make ice anyway without the computer board. I hope.
