Water housing leaking
I have a Whirlpool side by side that uses an Everydrop 1 filter. I’ve been running it without a filter for several months with no issues but it recently started leaking heavily from the housing. It leaks when the ice maker runs or when using the water in door. I don’t believe this model requires a bypass plug. Thoughts on how to stop the leak?
