Just replaced the control valve for water and ice. The valve is doing great but I have a water leak at the main water line leaving the valve going to the filter. On the old valve this was a threaded connection. On the new valve it is what I call a quick connect. I have recut the the line to ensure a clean stright cut using tube cutters and it is still leaking. I have ensure the line is fully inserted. What can I do to fix this leak? Is it a bad quick connect fitting. Thanks JT
Related topics
Quick connect leak | 6 | 8319 | November 19, 2010 | |
HELP! Leaky inlet valve | 1 | 362 | December 29, 2017 | |
fridgidaire water inlet valve leaking | 1 | 484 | November 21, 2017 | |
How to fix leaking water valve | 1 | 3193 | March 22, 2010 | |
water valve | 2 | 1669 | October 8, 2012 |
