water pools in bottom of refrigerator. No water is going into drip pan under fridge. Defroster hose clogged. How do I clean it out?
Do not use any wires - you can damage the drain hose.
Using a hair dryer make sure the drain is defrosted. Check the bottom end of the drain hose for a clog.
Using a hot water check if it goes through. If it does not then blow an air under pressure through the hose. You can use any kind of canned air.
